2022 Refresh Multi-Flex Tailgate Won't Open
Buck0451
Albuquerque
22 LT Trail Boss
USMC
I am looking for suggestions to get the tailgate to open. When buttons are pressed on the tailgate, remote and interior the tail lights flash but the tailgate will not release. I do not hear that solenoids click like before. The upper part will still open but not the lower. I have removed the panel from the tailgate and can manually release it but thats a nuisance every time. Any advice would be greatly appreciated.
I saw on here a little while back someone having this issue and I think it was a fuse in the footwell. I'll see if I can find it and that would at least be a place to start.
Think it was this one.
Thank you for the suggestion. I tried it and no luck. Your reply is much appreciated.
There is a way to lock out your tailgate by pressing and holding the touchpads on the tailgate itself for 6 or 10 seconds.
I don't think this is your issue, but might be worth looking into before you go to the dealer.
Also, your truck being a 2022 likely would have had the recall for the tailgate switch problems. Has this recall been performed?
