hawk99gt
I lIke the fender guards (trim). Are those stock or aftermarket?1.75" Ready lift with UCA....
22x10 -18 285/55/22
22x10 -18 285/55/22
what wheels are these?1.75" Ready lift with UCA....
22x10 -18 285/55/22
Ready Lift has solid products, imo.Thanks! Yeah, I'm just looking to level but wanted to be clear so I wouldn't get too many responses for an all around lift. Any suggestions on new UCAs?
Yes, I have the Ready Lift 1.75" on my '24 and the bed is dead level.Curious if the Ready Lift works on 2024 model? Their site says 19-23 but is there any difference in the TB LT from 23 to 24?
Also, can someone give me the stock wheel specs my 265/60/20s are riding on?
it passed because they dont pass you at night....do everyone a favor and adjust them
What wheel and tire set up are you running? Hoping I can run 285/65/20s with the RL and maybe 3/8 to 1/2 inch spacers. Or I might get +12 aftermarket wheelsYes, I have the Ready Lift 1.75" on my '24 and the bed is dead level.
You'll be fine with that tire size. ReadyLift might tell you that you need 3/8" to 1/2" wheel spacers to clear their UCA.What wheel and tire set up are you running? Hoping I can run 285/65/20s with the RL and maybe 3/8 to 1/2 inch spacers. Or I might get +12 aftermarket wheels
Hey I'm new here so I apologize if this has been said already. Does leveling the front void warranty? I'm assuming that if you do it through your Chevy dealer it would be fine.The vast majority only lift the front to level our trucks. Only those that want to retain a little rake will utilize a new rear lift block to raise it an additional 1”. Just make sure you get new UCAs since the stock ones are essentially at their limit with the factory lift.
Only thing you would need to do is adjust your headlights which is simple and you should have no issues with cameras or sensors.
305/55R20What wheel and tire set up are you running? Hoping I can run 285/65/20s with the RL and maybe 3/8 to 1/2 inch spacers. Or I might get +12 aftermarket wheels
No. The dealer and GM can refuse to honor your warranty if they can prove any modification caused failure. For example, leveling the front would have no impact on your radio.Hey I'm new here so I apologize if this has been said already. Does leveling the front void warranty? I'm assuming that if you do it through your Chevy dealer it would be fine.
But, It WILL effect your ball joints. / GO DO YOUR LEVEL< ADD THE UPPER ARMS and enjoy. in the rare event that a BJ breaks after...that is a simple fix and just numbers game of ALL companies having a potential failure of something they made.No. The dealer and GM can refuse to honor your warranty if they can prove any modification caused failure. For example, leveling the front would have no impact on your radio.
