3x3 Pod Lights for FF Matrix Bumper
If you are referring to the switches. I have the Auxbeam remote switchbox installed on the fuse box under the hood. Held on with industrial velcro.
I just have the control box sitting in the console - haven't mounted that yet. It's been out of the way and easily reached, so its not high on the list.
https://auxbeam.com/products/ar-800-multifunction-rgb-switch-panel-system-qp008526-1
View attachment 6923View attachment 6928
If you are referring to the wiring for the lights in bumper, it's all in wire loom that go to the switchbox above. Except for the fog lights, they are using the factory fog light switch.
Ditch lights have a hole drilled in the plastic covers by the windshield, the brackets a little expensive and are made by SDHQ. But they don't bolt to the hood.
Link to discussion on ditch lights and brackets : https://www.trailboss.org/threads/ditch-light-brackets-for-2021-tb-opinions-and-pics.1872/
Let me know if I answered your question or not, I can always take more pictures 📸
Looks great! Questions - For the auxbeam - what fuse did you tap? was is an ACC fuse? --- Did you run the wiring through the firewall port for the control box? if so, could you post some pictures of that. Thanks!
I’ll have to take a look what fuse and get you pics. But for reference on getting wires inside…
Look right behind the battery on the firewall there is a nipple right next to where all the cables go through on the passenger side, clip the end off the nipple goes right through and comes out on the passenger side.
Sorry for such a late reply, yes I tapped into an acc fuse so they will not come on unless the truck is on, or al least in acc.
