The Raven
- Joined
- Apr 25, 2023
- Messages
- 349
- Media
- 22
- Reaction score
- 213
- Location
- Reading PA
- Current Ride
- 2021 LT Trail Boss
Spoke with the dealer service department and they said that's how they are coming now without the sub. They said that they just install larger door speakers to get around having to put a sub in. Then I asked about what it would cost to have a factory sub put in and he said that I couldn't due to the BOSE amplifier that is installed already. I would have to go aftermarket in order to add a sub. Oh well. Other than that he did offer me to swing by and have them check the settings and if there was something wrong that they would fix it.
Yes this goes back to the issue that caused me to go looking for a pre-refresh truck instead of a new 2023. Modding ANYTHING AT ALL on the refresh trucks requires programming, and as of late last year and early this year, when I was shopping, there was no timeline on when doing that would be possible. The new architecture uses private key encryption so each module needs to be cracked individually each time it is flashed. So as far as I know, it's not even possible to swap amps at this time. You MIGHT be able to take the high level outputs from the factory amp and run them into a Maestro or some other kind of processor, then use that to input into an aftermarket amp and speakers...but that kind of setup rarely results in good sound.
Sucks to learn about this subwoofer situation but it's yet another thing that makes me happy I didn't buy the refresh truck.
