Lift float
Have you gone back through and tightened or inspected everything ? Other than a mindset, there should not be anything out of the norm happening.
Maybe a better explinantion of the float feel is in order.
When turning you say the rear feels loose....what size tire / brand / wheel and brand, if aftermarket wheel...do you have hub centric rings....
Make a solid list itemized of every mod.
No aftermarket wheels. Just tires increased from 33 to 35’s…. Explanation of float…🤔 loose is the only word to come up with. It feels like the back axle is not attached to bed or whatever tight…like a shock maybe broken or ?
Depending on the tire and PSI, the sidewall flex can be felt. is it more of a BODY ROLL feel or the rear of the truck hoppy across the rough surface
Finally fixed problem… I took it back to original place and they removed and reinstalled…. No more problems
good deal, so the correctly tightened what they missed before. Glad you have it all worked out.
