Shaun808
What size are your tires?I went with Borla 1.5 inch spacers with thread lock and torqued to 140 ft lbs. No rubbing and it gives the truck a good stance. View attachment 22682View attachment 22683
What brand of spacers?2021 Trail Boss LT with 2” spacers, stock factory rims, factory lift, no cutting and no rubbing. Gives the truck a nice wide stance
I wouldn't run spacers those factory wheels look good they just not neg offset so no matter the tire it not goin stick out much..Im same way I like the stock but don't wanna run spacers so eventually get more wheels probably around -18I'm new to this site but love the enthusiasm and information shared.
Here's my "issue" with my 2021 Trail Boss LT. I recently installed Falken Wild Peak AT4 285/70/18 tires and want to widen my stance. I also have wheel flares (not sure what style). I've watched video after video with all sorts of ideas/options. I would really like to not purchase new wheels as I like the original Chevy ones.
With the factory lift, is it better to try something like a 1 & 1/2" wheel spacer all the way around and will that clear all wheel well with the factory lift? I think the 1.5" is just right to match up with the flares. If I add the spacers, do I need to level the front end or is that just a recommended option?
Or ... do I spend the $ and get new wheels with a negative offset? I've heard -6 is good but as much as -12 was also mentioned.
Any thoughts/comments appreciated.
I have a 2020 sitting stock height...I'd like to get 295/60/20 BFG A/T KO3s under. Thinking I could put 1.5in Bora wheel spacers, to achieve better stance. I would rather not trim or cut anything. Thoughts?I had the same flares, removed them and am running 295/70 R18s that are just past the fender well.
