10 speed transmission fluid change interval?
I remember checking and changing transmission fluid not being an involved process. Times done changed. *yells at clouds*
This is what it looks like, it actually tells you everything from your build in detail. 💯 Times better than what you have.
Use to hide all the codes in the glove box on a sticker too...unless thats old school and they did away with that
Yep. It was really nice on my '08 with a dipstick. Just had to get the trans temp to at least 180* and check the fluid. Now it's just a little more involved but nothing terrible but I believe the temp requirement might be a little different between the gas motors and diesel. One thing to note is that the service/fill/drain plug is TIGHT. I had to heat the plug with a heat gun to get the factory threadlock soft enough.
I'm not sure when they did away with that but that was nice having it handy right there. My previous '08 was that way but when I got my 22.5, it was a QR code.
Since we were on the subject of transmission RPO codes, does the decodrpo app show the axle RPO codes too? There are two different rear axles and two different front axles (regardless of ratio). You need to know that because there are four different fluids depending on if you have the AAM or GM axle. To add to the confusion you can have an AAM rear and GM front or vise versa. Go figure.
Good info didnt know the axle thing
I gave some incorrect information...
While there are two rear axles and two front axles, there are only two different fluid numbers. One fluid for the AAM axles (both front and rear) and one fluid for the GM axles (both front and rear).
This is for the 22.5 trucks (start of the refreshed interior) so not sure if that's the same for the '25 trucks which is where your RPO codes come in real handy.
My wife's 2017 Tahoe still has the RPO code sticker in the glovebox so the did it that recently at least.
Anyone know the part number for the filter bolts for the gas engine not diesel or are they both the same?
DO you happen to know the part number for the bolts? For a gas 5.3L 2020 LT TB
You cannot buy just the filter bolts. You have to buy the complete valve body bolt kit. Give me a few and I’ll check my part number and see if they are the same for the gas engine
Reactions: Sly
