brewtus
How do you "test"? Aftermarket exhaust where you can hear it working or not? Curious to know for sure if a feature of L10 is to actually disable DFM.Finally got a chance to test it.. works as you stated. Thanks for the information.![]()
Thanks for followup! I was curious because that is the first time I've heard someone say DFM was disabled in L10.Updated previous entry about confirmation. I did another test and although the AutoStop is disabled with L10, I don't think the DFM is disabled. It is definitely disabled in L9.
Connected my OBD-II scanner but I couldn't find a setting that would show me if the DFM is disabled or not.
I just updated my Pulsar software to fix the speed limiter problem. So far so good.. Check engine light came on after the update. - LOL I cleared it with the Pulsar and it hasn't returned. While the Pulsar will leave no traces if you remove it before going to the dealer, note that it will prevent OnStar from running diagnostics on your vehicle. On demand diagnostics as well as the diagnostic scan in your monthly OnStar vehicle report will fail.
