Trail_Boss_6.2
Thanks for the info. Is there a way to tell what version of software is installed?
I am having the same issue.Holley sent me a cable to update my Pulsar LT. Unfortunately, the update did not fix my issue. They are now sending me a new unit.
Although a little frustrated with the issue, Holley is doing what they can to correct the issue. (Issue being the Chevy app can't connect to the diagnostics).
I talked to them last week about the same issue.Latest Update: Replaced unit with no configuration, everything seems to be good, ran it for a few days with no change to configuration.
Only thing to note, I could not turn off the auto stop via button, pressing button did nothing, light stayed illuminated.
Changed the configuration to disable auto stop, this broke the Diagnostic information. Turned off and diagnostic information back.
Disabled the DFM - diagnostic information is there.
In summary
* The unit connected seems to disable the ability to manually turn off auto stop via button
* With auto stop disabled via the Pulsar - diagnostic information on Chevy app does not work
* Disable DFM via Pulsar with Auto Stop (enabled) - diagnostic information is correct.
I will be passing this information along to Holley.
Thank you, I appreciate the info!Not silly at all.
The configuration is in the unit itself, so it does not change anything on the ECM itself - so when you remove it, you are removing the configuration changes.
In short, when you remove the unit, the truck is back to stock settings.
Hope this answered your question.
Hoping it will still detect any actual check engine lights or vehicles issues. I may have to test this out when I re-install my catch can.I talked to them last week about the same issue.
“The Pulsar LT will use the same communication line as the chevy app and OnStar diagnostic scans so it thinks the line is already in use. The App should still be able to detect any actual check engine lights or vehicles issues.”
Question for fellow Pulsar LT usersWanted to provide latest update.
After making 4-5 trips in the truck, the app is working fine.
Remote Start - will start and stop
Diagnostics - shows all information (No Issues Found).
This is very strange and makes me wonder if this is something Chevy (GM) app vs. an issue with the Pulsar.
We will probably never know. Good luck to all who have.
