Which level kit
I also went with the Bilstein 6112 (set at max height 1.2”)/5160 combo. I have the 5160’s installed waiting on the 6112’s to arrive. For the UCA, I went with the Bilstein. Hoping I have the same experience as everyone else who went with this setup.
Forgot to post on here but ended up going with the 2inch ready lift sst and I also had the block put in the back. Has 3/4 inch of rake. Went with Nitto Ridge Graphlers 285/70/18. 34 inch tire. Would’ve done 35’s but didn’t want to deal with rubbing and all that. I think it looks great
I decided on going with Bilstein 6112 (set at max height 1.2”)/5160 combo and definitely night and day difference over the Ranchos. Also went with Rough Country’s UCA. Ride is so much smoother.
I did the same build but with Cognito UCAs.
Finally got the 6112’s installed and alignment. Glad I went with Bilstein, the ride is so much better and being leveled, feels so much better in the driver seat. To note, I watched a bunch of videos on the installation which was a breeze, but non showed the recommended cutting off of the bump stops for the UCA which I performed.
Also they recommend special grease for the Polyurethane bushings, keep that in mind before tacking, I had to drive 30 min to pick it up. Overall very happy 😃
1. Did you stay stock height ( it does not sound like it)
2. Stock control arm ???
i only ask, as cutting the bumps is a really good way to destroy BJ on droop...having the arms helps that...
I just drove +200 miles and I am so pleased with the Bilstein setup. The truck feels more planted on the road. The suspension is slightly stiffer in a good way. As others have said, this is how the truck should have been setup from the factory.
Not great pics but I got some this weekend.
Cognito performance kit 1” lift, w/fox 2.0 & UCA
Paired with 285/75R17
Dude ive been looking at the congito leveling kits. Torn between the 2.5 fox elite and the 2.0 performance. You liking it?
I also have seen some concerns with getting 17s on my 2023 due to the little bump on the break caliper. 17s are the way to go though they look dope
if budget allows, always go with the most adjustability. i can not say enough good about the 2.5 Elites.
took 2 people for rides today...both were amazed by the ability to adjust and feel so much change, so quickly
