Biggest tire on stock boss
You will need spacers with stock wheels to get any poke, or go with new tires and wheels to run without spacers
Does anyone on here have just a leveling kit and 12.5 inch wide tires with no spacers?? If so, any pictures??
305/65 yes it’s leveled, but I lowered the rear with these
Looks good👍
So the front is stock and the rear is lowered about 1 inch correct?
Love the look of this truck! I’m thinking about doing the same set-up on mine, did you have to trim any? And would you happen to have any side shots? First post btw.
No trimming just get the musflap delete kit and you're good to go
I’ve read that running bigger tires with the 10 speed trans can lead to early failure-anyone else read this?
No,If that’s the case why are dealer’s putting on bigger wheel and tires?
I posted the link and it’s awaiting moderator approval.
If you don’t go crazy and stay with 37s or below you won’t have any problems.
Anybody running 33x12.5x20?
Assume they would rub without some trimming?
I took it to a commercial vinyl installer I didn’t want to mess it up you basically have only one shot to get it perfect… less that $50 for labor
