Biggest tire on stock boss
I’m running 1.5in BORA spacers with factory wheels and 295/70/18 tires. I had to trim the mud flaps but just the part hidden inside the wheel well. I also had to remove the bracket that was tucked behind the liner.
Same setup here. Minor mud flap mod. No big deal
Hey y'all. I'm new to the forum. I just bought 17 x 9 -12 offset wheels for my 2020 Trail Boss. I have a 2" supreme suspension leveling kit. I want to run 35 x 12.5 tires. Is anyone running the same setup? If so, do they rub at all? Or, do I need to get spacers?
I have 35 x 12,50 with 2" leveling, no problem at all.
wondering what tire sizes you guys are getting away with without additional lift! I'm wanting to stuff 305 65s on my stock wheels.
I was wondering the same thing but was also wondering if there is a way to level the back of the truck. It has a 2 inch block but no one seems to be able to tell me if you can remove it and put in a 1 inch block. Thanks
Here’s the difference in 2” and 1” blocks,lower it 3/4 of a inch and that 1” block is GM take about 40mins to change out easy
Where did you get that 1 inch block? Im having a hell of a time finding them.
I run 295/70 yokahoma x-at, on stock 18. No rub, no spacers. Places them right at the outside edge of the fender. Spacers would put them outside and look great IMO. With spacers the 295/65 will fit.
I have 295/70 Toyos on stock 18s. 2in level kit. They did not rub anything until I added 1.5in spacers. The fronts just barely rubbed the wheel liner near the mud flap.
it was an easy fix👍
do you have a level kit or stock height? truck looks great
Thanks. I have 1.5 level with factory uca's. They fit without the level with some minor rub at full lock. Level solved it. My angles after level and alignment are almost identical
Sorry about being late, but if you still looking here the information, GM part center they called Leaf spring spacer # 84379975
Nitto Trail Grapplers 33x12.50x18LT. Fit great and look great.
Looks great did you have any issues with rubbing on your upper control arms with that wide of a tire ? Any side view stance pics ... that’s a size that I think is perfect without having to cut or modify fender liners ect..
Looks nice and it does fill out wheel wells .... just don’t know how’d they do in sand , which is what I would be using them for (beach community)... since they are a bit narrow ... but I do really like the dura tracs my TB came with just with they were a bit larger at least a 70 vs the 65...
