KRAKIN68 2021 Trail Boss Build
Were those directions or whatever the are called I saw?
Really nice though! Gives me some ideas. I'm to the point as where do you stop. I'm already deciding between a twin-screw and a Procharger for mine.
Next tree mods…
1 AVS Hood Deflector Pro
2 Truck Bed Rail system (kayaks).
3 Combo Light Bar (placed behind the grille
Are you asking about the blue replacements, or the ones integrated in with the rough country facia ?
i have tied to stay away from the engine and tranny due to some of the mechanical issues some are having.
I have. Road trip from Ohio to Seattle and back to move a child back closer to home after first job out of college.
I would agree about where to stop. It can turn into a sickness. 😂
Forgot to add these in. bed cover was one of the first mods. I went with the Retrax HD I think it’s called…. Third truck I have owned with it. Other than the loss of a little bed space, it hands down is one of the best hard retractable tonneaus. I would argue it is the best, but a bit pricy.
Also when I was doing the initial normal first month add ins that all do…..
i needed to run the wires for my Radar Detector and Dash Cam Setup. This is one of my favorite mods Because everything comes out so clean. I did find a harness being unused in the ceiling with like 12 or 14 gauge power wires that was not being used but I still ran my own directly to my fuse box I put in. i bet the u used harness was for the sun roof option. I wanted a clean and dedicated fused connection for the Escort Max 360c and the BlackVue DR900X-2CH Plus 4k.
From this…..
to this.….
on the less invasive side I added this antenna. Little if my signal loss of FM and FM HD, and SXM.
Next tree mods…
Only down side to the AVS light hood protector that I have continued to see and why I did not get is at higher speeds the aerodynamics is lost and the hood starts to lift and like move due to the wind hitting the protector.. I saw they just came out with a new version so not sure if that fixed it or not
Great work on all these electrical mods, but hopefully you never get any electrical glitches like some of us have experienced, because GM will blame it all on your wiring.
I bought the newest version so we will see.
True. I only tapped one wire with an “add-a-circuit“ and taps from the rear of the head lamp light assembly plug. Everything else is off the main battery to my separate fuse box With disconnect etc like you see in the pictures. Directly off the terminals, too so less they can say but I am planning to put a second battery in tandem with A disconnect as well just in case. No wiring issues yet But I would agree you roll the dice when it comes to your local gm service center.
Fingers crossed.
From this…..
to this.….
do have any direction on how you did the upfitter switch in the headliner? I have been looking for a spot to mount something like that and this is freakin clean!
I wasn’t looking for it but there is a pretty good install video some guy has on the upfitter switches on YouTube.
