I heard cylinder deactivation is what is helping to prompt the lifter failures. I had one go bad on my driver's side at about 11,000 miles. I immediately purchased a Superchips tuner (also deactivates DFM like the Pulsar LT does) and deactivated DFM. I am now just shy of 30,000 miles, no more issues so far. I think keeping those engines in permanent V8 mode is the best preventative measure you can take. Oil catch-cans are helpful too.See this post. I am asking the question if anyone actually has success with PULSAR LT preventing lifter failure - those that have run it and have high mileage without lifters failing.......
Pulsar LT preventing lifter failure?
OK, I just kicked over 8k miles on my '21. I was purposely waiting until then to disable DFM to make sure I didn't have the lifter failure, as the original TSB was for 8k to replace both banks if they fail, now its up to 16k miles. Anyhow, I am thinking of the Pulsar LT to prevent the...www.trailboss.org
Curious as well. I had an opportunity to change my refresh order due to a running board constraint, so I went from the 6.2 to the 5.3, mostly due to gas $$ but the fact that the 5.3 didn't have DFM didn't hurt either.For sure, just didn't know if anyone else with the Custom 5.3 without DFM/AFM has had or heard of any issues.
What type of can did you go with, heard people complaining about vacuum leak noise with the JLTYes I also have a catch can. No issues whatsoever. It's quite surprising that the can is about a third of the way full after 3,000 miles on a newer engine. They are worth the money for sure!
Mine is the J&L oil separater, no problems with it so far! They have since merged with a company called OSC, so the appearance is a little different now. But I am pretty sure it is still the same product. Link below:What type of can did you go with, heard people complaining about vacuum leak noise with the JLT
Should have got the extended warranty, my 2022 trail boss is a 2022 but w/o DFM so I don’t plan on having lifter issues since it came from the factory without DFM but everyone knows about the lifter issues so not buying extended warranty is kind of a dumb decisionDoes anyone know what happens if the vehicle has this same issues after the 3 year 36K warranty? Makes me nervous that my truck has around 48,000 miles on it and could possibly fail.. Definitely something I would not want to pay out of pocket to fix.. Maybe it’s time for me to start looking at the new ZR2 if that the case.. Best of luck, and definitely demand GM gives you a rental vehicle..
Same thing happened to my husband's truck this week. Lifters had to be replaced and a bent rod. Only 19000 miles on it! Picked it up today and the work was for a recall now. Unbelievable! So watch out for a recall. Dealer didn't even inspect the truck. Pretty disappointing!2020 Chevy Trail Boss with the 5.2
So, last night, the truck started ticking and shaking a bit, then the service ESC came on, then parking brake light. Parked it for the night, got up for work and left the house at 3 a.m, didn’t even get off our street and check engine light and transmission light came on along with the ESC and parking brake light again, only this time, it was ticking, shaking, and making worse noises. Turned around and parked it back in the driveway and waited for the local Chevy dealer service dept to open and drove it roughly 3 miles tops to the dealership to drop it off. Truck has only 20k miles. Anyone else had this problem or know if it’s a known issue?
Thanks!View attachment 3421
